1999 Buick Lesabre, CKP Sensor, CMP Sensor, FP, Injector, MAF, MAP Sensor Waveform
Posted to the Waveform Library on 6/18/1999
This is the display from an MTE98-01p Vehicular Data Recorder developed by Master Tech Engineering, Inc. ([...]) It is a 16-channel (including fuel pressure) endless loop type flight recorder (Black Box) showing an intermittent Mass Air Flow Sensor (MAF) on a ...
1999 Buick Lesabre 3.8L
Engine3.8 L / 6 cyl
Component, , , , ,
Engine3.8 L / 6 cyl
Component, , , , ,
