1991 Mitsubishi 3000GT, CKP Sensor, CMP Sensor Photo
Posted to the Waveform Library on 3/26/2003
Test Point location for the CKP & TDC (CAS) on the right side of the Intake Manifold. Accessible from the right fender work area. Both Sensors are co-located in the same assembly. The red 4 wire connector in the center of the image may be backprobed with embro...
1991 Mitsubishi 3000GT SL 3.0L
Engine3.0 L / 6 cyl / GAS
Component,
Component,
