1991 Mitsubishi 3000GT, IC Circuit Photo
Test Point location to gain access with an Amp Clamp and/or Voltage probes. The 3 Blue wires on the left are the ICM Outputs (pin ID 7 ~ 9) to the 3 DIS Coil Primary Inputs. The 6 wire connector leftmost 3 wires are the ECM Outputs to the ICM (pin ID 1 ~ 3). G...
| Component |
1991 Mitsubishi 3000GT SL 3.0L
| Component |
