1994 Ford Thunderbird, CKP Sensor, CMP Sensor Waveform
This is a waveform shows crank and cam position sensor relationship. The blue trace is the crank position sensor and the green is the cam position sensor. The cam sensor intersects the crank sine every other 85 or so degrees after the missing tooth. The cam se...
| VIN | 1FALP62W5R |
| Engine | 4.6 L / 8 cyl / GAS |
1994 Ford Thunderbird LX 4.6L
| VIN | 1FALP62W5R |
