1988 Honda Civic, Ignition - Primary Waveform
The top primary is with no spark due to a defective coil. Note the early current limit and high ground offset at initial on. Thia type of coil failure is likely to damage an igniter. The bottom one is after a new coil. The igniter was also replaced on recommen...
| Engine | 1.5 L / 4 cyl |
1988 Honda Civic 1.5L
