1987 Pontiac Fiero, MAP Sensor Waveform
Posted to the Waveform Library on 11/1/2002
Ok, this is not normal way to look at MAP sensor signal... I've taken it at a fast time base and am zeroing in on the actual signal to use it as a vacuum waveform rather than just looking at it to see if it is a valid input to ECM (which it is). Refer to Tom C...
1987 Pontiac Fiero Sport 2.5L
Engine2.5 L / 4 cyl / GAS
Trans5-speed StandardTransaxle
ConditionKnown Good
ConditionKnown Good
