Archaeological find
1972 IH loadstar 1800 345 gas. Clutch lever failure at high rpm and load, scattering pressure plate and bellhousing. Red parts are engine block, all parts are as found on highway. Transmission was held in place only by shift lever lodged between driver's seat ...
OPEN: This is what happens when your truck hits 8500rpm |
TECH: Clutch Forensic Analysis
TECH: Towing with the engine running...
TECH: Clutch Disc Explodes
THEORY: 94 Ford Pick-up clutch will not dis-engage
HD/FLT: '99 superduty clutch failure
HD/FLT: another one's gone
HD/FLT: ...in the archives
HD/FLT: Detroit Diesel Allison 8.2 Block
