2014 Fiat 500L Trekking, Transmission Waveform
Capture of a non-responsive SDU. Ch1 Command, Ch2 Feedback, Ch3 Ground circuit from motor. Ch4 Motor current. The TCM begins with a signature signal(not shown), then commands 0%, The feedback needs to respond with 3 volts. The TCM will slowly ramp up the duty ...
| Engine | 1.4 L / 4 cyl / GAS |
| Trans | 6-speed AutomaticTransaxle |
| Subsystem | Transmission |
2014 Fiat 500L Trekking 1.4L
