2014 Fiat 500L Trekking, Transmission Waveform
Posted to the Waveform Library on 8/26/2025
Capture of the DDCT SDU, controlled ground is not enough to run pump. Code P1CC0-00 will be set. Ch1 Command Ch2 Feed back Ch3 V Feed to electrohydraulic pump Ch4 V- Feed to electrohydraulic pump
2014 Fiat 500L Trekking 1.4L
Engine1.4 L / 4 cyl / GAS
Trans6-speed AutomaticTransaxle
SubsystemTransmission
ComponentOther
ComponentOther
