2013 Buick LaCrosse, ECM/Inputs/Outputs Schematic
5V2 is not shared with any other sensors. The reference and ground for the CKP are a series circuit. 5V3 and 5V4 each supply 2 sensors. Notice the APP sensor uses separate 5V references, but shares the ground. The MAP sensor circuit is in parallel with only on...
| Engine | 3.6 L / 6 cyl / FLEX |
| Component |
2013 Buick LaCrosse 3.6L
| Component |
