2016 Hyundai Veloster Turbo, Ignition Waveform
The green trace is the IC trigger, the blue trace is the current ramp for that coil. You can see the coil starts charging but the IC signal never reaches 5 volts and terminates immediately.
| Trans | 6-speed AutomaticTransaxle |
2016 Hyundai Veloster Turbo 1.6L
