2018 Chevrolet Equinox Premier, Ignition Waveform
2018 Equinox 1.5 (LYX) Known bad Red=Crank, Blue=Int, Green=Exh. Please note that Exhaust reluctor it was moved 2 degrees off on the scanner, and was only showing one line off compare to crank signal.
| Engine | 1.5 L / 4 cyl / GAS |
2018 Chevrolet Equinox Premier 1.5L
