2016 Jeep Patriot Latitude, ECM/Inputs/Outputs Waveform
Green CKP,Purple and Yellow Cam 1&2,Red is injector volts, Dark blue coil primary,Light blue Pcm voltage,Gray is coil 12 v feed [...] has a bad Tipm and or connection.
| Engine | 2.4 L / 4 cyl / GAS |
| Trans | 0-speed AutomaticTransaxle (Electronic) |
2016 Jeep Patriot Latitude 2.4L
