2008 Ford F-150 Lariat, ECM/Inputs/Outputs Waveform
5.4L SOHC with VVT Taken at approx 600 RPM. Green Trace is CKP. Red Trace is CMP Bank 1. Blue Trace is CMP Bank 2 Aside from a slightly low amplitude in the first swing of the B2 CMP (possible slightly bent tang on phaser), I think this is a good pattern.
| Condition | Unknown |
2008 Ford F-150 Lariat 5.4L
