6 and 12 volt batteries in parallel
6 & 12 volt batteries wired in parallel. Each has internal resistance of .02 ohms. Current 150 amps, assume current direction negative to positive. Note that current direction in the 6 volt battery is opposite to when it would be powering a load. The volt mete...
