2012 Dodge Avenger R/T, ECM/Inputs/Outputs Waveform
The vehicle would very intermittently stall and crank but not start. The CKP signal is inverted in this waveform. The 5V bias should be pulled down instead of being pulled up. New CKP sensor solved issue.
| Engine | 3.6 L / 6 cyl / FLEX |
2012 Dodge Avenger R/T 3.6L
