2012 Volkswagen Touareg TDI Executive, BATT/Charging/Starting Waveform
Yellow trace is starter current Green is camshaft sensor Blue is injector cylinder 1 Red is vacuum of left bank intake manifold only measured at port that is factory installed by the manufacturer. We suspect this engine has a mechanical failure - broken chain...
| Engine | 3.0 L / 6 cyl / DIESEL |
| Trans | 8-speed AutomaticTransmission (Electronic) |
2012 Volkswagen Touareg TDI Executive 3.0L
