2014 Dodge Grand Caravan Crew, Engine/Propulsion Waveform
Engine cranking, the blue channel is a pressure transducer in the tailpipe to compare each cylinder's exhaust stroke pressure pulses. The green channel is a pressure transducer in the intake manifold to compare each cylinder's intake stroke vacuum pulses. The ...
| Engine | 3.6 L / 6 cyl / FLEX |
2014 Dodge Grand Caravan Crew 3.6L
