Batteries wired series voltage opposing plus diagram battery being charged with separate loads
The effective voltage across the battery internal resistance, which is .3 volts, can not be measured directly. In order to understand that the effective voltage (.3 volts) across the battery internal resistance, as it is being charged is .3 volts you must unde...
