Parallel connected batteries of unequal voltages
Current will flow through the lower voltage battery in opposite direction to when it is powering a load. The 12.6 volt battery will charge the 12.3 volt battery until their voltages become the same. The effective voltage across the lower voltage battery is .3 ...
