2013 Mini Cooper Countryman, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 10/6/2022
KNOWN BAD waveforms of electronic throttle body actuator motor, green trace is not switching between 0-12V like the yellow trace does. Both wires go to PCM and thru transistors.
2013 Mini Cooper Countryman 1.6L
Engine1.6 L / 4 cyl / GAS
Trans6-speed AutomaticTransaxle (Electronic)
ComponentOther
ComponentOther
