2003 Honda Accord EX, ECM/Inputs/Outputs Waveform
This is a crank/no start. Would fire a cylinder every so often. The problem is a missing tooth on the crank sensor wheel. You can see it as the large space on the blue trace just before the cam signals. As far as i know the timing is OK so this is a good pa...
| Engine | 2.4 L / 4 cyl / GAS |
| Component |
2003 Honda Accord EX 2.4L
| Component |
