2003 Ford Taurus LX, Ignition Waveform
In the yellow channel, the first primary coil winding voltage shows the secondary arcing with no spark arcing across the spark plug air gaps. The green channel shows the secondary arcing with no spark arcing across the spark plug air gap
| Engine | 3.0 L / 6 cyl / FLEX |
2003 Ford Taurus LX 3.0L
