2003 Ford Taurus LX, Ignition Waveform
Posted to the Waveform Library on 5/5/2022
The red channel shows that the PCM is switching the primary coil winding off correctly. The green secondary shows a lot of spark arcing and no spark across the spark plug air gap. The yellow channel is the primary coil winding and the scope channel should be -...
2003 Ford Taurus LX 3.0L
Engine3.0 L / 6 cyl / FLEX
SubsystemIgnition
Component,
SubsystemIgnition
Component,
