2016 Dodge Charger Pursuit, Engine/Propulsion Waveform
The engine would only misfire while accelerating near WOT. The blue channel is COP1. The red channel is the starter amps and the green channel is a pressure transducer in the intake, with a repeating bad intake stroke vacuum pull.
2016 Dodge Charger Pursuit 5.7L
