2012 Ford Focus SE, ECM/Inputs/Outputs Waveform
Both int & ex cam lobes pointing in the same direction, i.e. intake cam approx. 90` retarded. Run with no oil filter for 15 minutes. Had 165psi compression. Scan tool reported no codes, good cam/crank sync., zero degree cam retard desired and actual but no co...
2012 Ford Focus SE 2.0L
