3.6 Dodge oil passage schematic
Shows oil from pump entering block passage at bottom left of block. Oil is distributed to centre main galley. Looks like there is a supply to feed right lower mounted timing chain tensioner and high/low oil pump supply oil via the small hole on the right side ...
