3.6 Dodge variable oil pump
Posted to the Waveform Library on 12/9/2021
Variable vane pump, used as high volume or low volume by solenoid controlling system oil pressure to backside of pump cam ring. Spring gives default of low volume, solenoid allows cam ring to pivot against spring to increase volume, and normally double the inc...
