1995 Ford F-150 Eddie Bauer, Ignition Waveform
The PIP signal with a Motorcraft module. You can see a small distortion due to the module interacting with the signal, but it is clearly pulling down to zero volts.
| Engine | 5.0 L / 8 cyl / GAS |
1995 Ford F-150 Eddie Bauer 5.0L
