1994 Ford Explorer Eddie Bauer, Ignition Waveform
Posted to the Waveform Library on 10/1/2021
The blue channel is the PIP cranking to start. The scope lead ground is on the negative battery terminal and the PIP has 0 ground voltage drop. The black channel is the coil amps
1994 Ford Explorer Eddie Bauer 4.0L
Engine4.0 L / 6 cyl / GAS
Trans4-speed AutomaticTransmission
SubsystemIgnition
ConditionKnown Good
SubsystemIgnition
ConditionKnown Good
