2006 Acura TL, Engine/Propulsion Waveform
This vehicle will not Idle. Scoped the Cam and the Crank and compared to a good one to find the crank and cam are not lined up correctly, Confirmed the timing belt is off by at least 2-3 teeth.
| Engine | 3.2 L / 6 cyl / GAS |
2006 Acura TL 3.2L
