2005 Subaru Outback i, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 5/25/2021
Vehicle has a P0335 stored. Scoped ckp and cmp for grinns. Interesting to find the timing off 10 degrees (each of the smaller peaks are at 10 degrees apart. Larger are 30 degrees.) Cursors are placed where the cam signal should be. Prolly a tooth off.
2005 Subaru Outback i 2.5L
Engine2.5 L / 4 cyl / GAS
