2006 BMW 530xi, ECM/Inputs/Outputs Waveform
This is the two can bus lines with the lines cut at the gateway. This is reading the gateways output. The spikes on the two lines are running on different time base. Is this normal?
| Condition | Unknown |
2006 BMW 530xi 3.0L
