2011 Ford Escape Limited, BATT/Charging/Starting Waveform
The blue CH A is the battery volts. the red CH B is an amp clamp on a battery cable and the amp trace shows a repeating 6.1 amp draw for 7 seconds each. The time between each amp spike measures 26.64 seconds, until I pulled the rear wiper fuses.
| Engine | 3.0 L / 6 cyl / FLEX |
2011 Ford Escape Limited 3.0L
