2014 Hyundai Elantra Coupe GL, ECM/Inputs/Outputs Waveform
The red CH B is the VCT solenoid PWM voltage. In the green CH C, I connected a jumper wire to the solenoid's control wire and I put a current probe around the jumper wire. When I tapped the jumper wire to ground, the pintle hump shows the pintle is being pulle...
| Trans | 6-speed StandardTransaxle |
2014 Hyundai Elantra Coupe GL 2.0L
