2010 Ford F-150 FX2, ECM/Inputs/Outputs Waveform
Intermittent no start and stalling maybe once a day, then it sets several U codes. Here I'm scoping the DLC pins 6,14 and I slapped the under hood fuse box. The engine didn't stall but the capture has a 70ms glitch caused by a bad solder connection in the clus...
| Engine | 4.6 L / 8 cyl / GAS |
2010 Ford F-150 FX2 4.6L
