2006 Ford F-150 XLT, Engine/Propulsion Document
One tooth off- Blue=B1, Green=B2, Yellow=CRK, Based on all info I found both banks should match each other. The middle peak should line up just before the 5th short peak on the crankshaft trace, much like B2 does. After this test I opened timing cover and fo...
| Engine | 5.4 L / 8 cyl / FLEX |
2006 Ford F-150 XLT 5.4L
