2016 Dodge Charger Pursuit, Engine/Propulsion Waveform
Misfire in cylinder 1 at WOT, The blue CH A is the COP1, the red CH B is the starter amps, the green CH C is a pressure transducer in the intake and it shows cylinder 1 with a repeating weak intake stroke vacuum pulse.
2016 Dodge Charger Pursuit 5.7L
