2005 Acura TL, Engine/Propulsion Waveform
CH A injector 1, CH B is a WPS500 in the intake, to compare each cylinder's intake stroke vacuum pulses, CH C is a FLS in the tailpipe and it shows a cylinder with a small exhaust stroke pressure pulse, CH D is the starter amps
| Engine | 3.2 L / 6 cyl / GAS |
2005 Acura TL 3.2L
