Ignition trigger cyl3 over crank at idle
This image was taken to verify spark timing using crank and ignition trigger on cyl3. Vehicle has a rich condition at idle, low vacuum (16.7kpa) and high idle. Idle at the time of this capture was 1200rpm. Timing appears to be retarded in this image?
