1993 Toyota Corolla, Ignition Waveform
The blue CH A is the coil primary winding voltage and the spark burn time measures 1.5ms. The red CH B is injector 1 volts. The green CH C is the coil primary winding drawing 5.7 amps
| Trans | 3-speed AutomaticTransaxle |
1993 Toyota Corolla 1.8L
