2017 Ford Explorer XLT, Engine/Propulsion Waveform
Yellow trace is delta pressure sensor in tailpipe, green trace is ignition coil command for cylinder #1. Where the ignition coil waveform changes is where I unplugged the coil pigtail, to show the effect in tailpipe exhaust pulses.
| Engine | 2.3 L / 4 cyl / GAS |
| Component |
2017 Ford Explorer XLT 2.3L
| Component |
