2014 Ford Focus SE, Emissions Scan Data
Replaced the upstream AFR sensor. Then sprayed hydrocarbons into intake tube to force AFR sensor rich, as seen at the first green circle. Then performed a snap- throttle to force it lean. Sensor should reach at least /-2.4mA to indicate a healthy sensor. Take...
| Subsystem | Emissions |
2014 Ford Focus SE 2.0L
