2006 Jeep Liberty Limited, BATT/Charging/Starting Photo
There is no power to the starter relay pull in winding when the key is turned to crank. I am using a regular test light connected to battery positive to feed B to the fuse that feeds power to the starter relay pull in winding, then the engine cranks and star...
| Engine | 3.7 L / 6 cyl / GAS |
2006 Jeep Liberty Limited 3.7L
