Code P0366, P0391, P0341 or P0346
If the camshaft adjuster lock pin breaks inside the adjuster you will get Start/Stop failure messages and the engine will be delimited to 3500 RPM'S. You "MAY" have a stored fault in the ECM for Camshaft Position Sensor Circuit Range/Performance pointing to wh...
