2005 Acura NSX, Engine/Propulsion Waveform
P0304, CH A injector 1, CH B is a WPS500 in the purge hose to the intake, CH C is a FLS transducer in a tailpipe with sponges in the tailpipes and there is a valve issue, CH D is the relative compression amps.
| Engine | 3.2 L / 6 cyl / GAS |
2005 Acura NSX 3.2L
