P0088 Fuel Rail System Pressure
A stretched timing chain will cause fault P0088 Fuel Rail/System Pressure - Too High. If you remove the plug on the front of the timing cover you can inspect the tensioner. This picture is of an over extended tensioner. If seven or more groves are visible rep...
| Engine | 2.0 L / 4 cyl / FLEX |
| Trans | 8-speed AutomaticTransaxle (Electronic) |
| Subsystem | Not Applicable |
2014 Audi Q5 2.0T 2.0L
