2006 Ford Escape Limited, Engine/Propulsion Waveform
CH C relative compression amps and some of the cylinder piston rings are fuel washed. CH D is a WPS500 on the dipstick tube and some of the low compression cylinder pressures are leaking into the crankcase.
2006 Ford Escape Limited 3.0L
