2006 Ford Escape Limited, Engine/Propulsion Waveform
CH C relative compression amps, with some cylinders with fuel washed piston rings, CH D is a WPS500 on the dipstick tube. Some of the low compression pressures are leaking past the piston rings, into the crankcase.
2006 Ford Escape Limited 3.0L
