2009 Nissan Versa 1.6, Ignition Waveform
The blue trace is the tailpipe pressure during an ignition misfire. The red trace is the ignition sync for the misfiring cylinder. During the misfire, the combustion process does not take place. After the expansion stroke a vacuum is created prior to the exhau...
2009 Nissan Versa 1.6 1.6L
